When placing pressure transmitters in a model one transmitter is placed down stream of another transmitter and a differential pressure is read between the two. The transmitters are considered one unit, but Plant3D is seeing them as 2 and therefore is not allowing the same name to be assigned to both. Does Plant 3D have a method of allowing us to assign the same name to both so that we do not have to manually update the iso’s afterwards?
Solved by George.Endrulat. Go to Solution.
Not that I'm aware of, you can do something like that in P&ID, not 3D. What we do for pdit/dpits is to have either an A or B after the number, A on the upstream, B on the downstream.
