to weld a 1"dia stub-in nipple to a 6"dia Victaulic main pipe
diacreek
diacreek
How to to attach (weld) a 1"dia stub-in nipple to a 6"dia  Victaulic main pipe.
It seems the Victaulic spec don't allow to do the welding.
h_eger
In Victualic Spec are the EndCodes GRV.
These are not suitable for Stub-In.
Check first time whether the pipe material allows a Stub-In.
Then you need only the Spec Editor each nominal size with the end code BV creating thereafter it should work.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ryan.bales
Autodesk Support
Autodesk Support
Did you get to try @h_eger's solution?
Ryan Bales
Fusion 360 Product Support
diacreek
Dear Sir or Madam:
My guys tried out. It seems not work.
more solutions are needed on how to put a stub-in into a Vic pipe.
Thanks a lot.
Bill Wang P.Eng.
Diacreek Engineering Inc.
3034 Palstan road
Suite 202
Mississauga ON L4Y 2Z6
O: (905) 279-9085
C: (416) 908-5206
www.diacreek.com
diacreek
It seems not work.
Any more measures.
ryan.bales
Autodesk Support
Autodesk Support
It really depends on how your are doing it. If you want a stub-in you'll need to make sure that stub-in's are in your branch table settings. Then in Plant 3D make sure "Toggle Stub-in's" is turned on.
If you want a part, say like a pipe nipple, they already work that way. I would copy a default ASME or equal pipe nipple into the spec you need and go from there.
Ryan Bales
