Hello Forum,
One of our projects will not succeed in 'uploading' to Vault. We receive the error "The path is not of a legal form".
The steps we take.
Other information:
Is there someone out there who has any ideas on how to solve this? Or to help narrow our search radius in order to find the problem in this project?
Thank you in advance!
Wouter
Solved by wouter_jansen_SCW. Go to Solution.
Thanks for your reply @Tomislav.Golubovic.
Other projects are succesful in uploading to the Vault, which means it can't be my profile.. right?
Server is also the same build as client side.
Thank you for your reply @Tomislav.Golubovic .
As you can read in my post, other projects succeed in uploading. I am looking for help to try to narrow down the search to what could be the issue with this project.
Do you have any ideas what can be corrupt in this project? The error refers to a path not being legal, but what kind of path? I can not find any non-allowable characters in file names, all x-refs are functional and do not refer to files outside of the project and it seems that there are no paths exceeding 256 character length.
I dont work with Vault but I have similar issue with project on NAS, so if I enter project path "\\NASLocation\myProject" it will show that error. As I already map the location to a drive name "X" then I enter project path = "X:\myProject" then the issue gone.
Hope it may help.
This kind of error is very difficult to solve remotely, does your reseller give any support on this? Have you contacted Autodesk support?
I have contacted Autodesk support, they asked me to verifiy some things regarding location.. permission and such. But I managed to solve it before they had the chance to provide me with the freeing answer.
What did it for me was:
