AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Taping connection not working in metric upvc GF
9 REPLIES 9
Message 1 of 10
772 Views, 9 Replies
Hi all i am trying to make a tap connection of male adaptor in DN150 pipe but its not working. i am using GF catalogs.
same thing i can make in cpvc sch.80 piping but its not working in upvc metric catalog. please check the attached shot for cpvc its working but not for pvc. can someone guide me about this issue.
thanks and kind regards.
9 REPLIES 9
Message 2 of 10
h_eger
h_eger
Dear @Anonymous ,
it doesn't work because it shouldn't work at all!
In such a position no further welding / adhesive connection may be incorporated as the complete integrity of the strength is weakened.
even if it is done in practice, the manufacturer does not allow it!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @Anonymous ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 3 of 10
in reply to: h_eger
thank you for reply. i am not saying its good or not. my question is this that why it is possible with cpvc and not for upvc. any help about this????????
Message 4 of 10
h_eger
h_eger
I have cpvc in GF content, not upvc!
Where did you get the upvc content from?
Attached is the content list from the Autodesk App Store for GF catalogs
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 10
in reply to: h_eger
inside this content pack there is PVC catalog 1 and PVC catalog 2. these catalogs have uPVC fittings. please check the attached pic.
thank you
thank you
Message 6 of 10
rajendra.prajapat
rajendra.prajapat
@Anonymous  are the units same for both components.
Message 7 of 10
h_eger
in reply to: rajendra.prajapat
h_eger
Dear @Anonymous ,
add in the configuration under Piping Connection Settings -> Tap joint under End 2 PPL or which EndCode dur use for your connection.
Update der Medien
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear @Anonymous ,
Update der Medien
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 10
yes this is a metric catalog for pvc. pipe size is 160mm or DN150 and adaptor is male threaded dn15x1/2" .
Message 9 of 10
h_eger
h_eger
Dear @Anonymous ,
Attached is the image documentation for the Piping Connection settings in the configuration.
There was previously a problem with the Plant 3D Forums website
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear @Anonymous ,
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 10
in reply to: h_eger
THANK YOU EGER FOR THE SUPPORT. 🙂
KIND REGARDS
KIND REGARDS
