Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Symbols Auto scale
Mohammadjamali75
Symbols Auto scale
Mohammadjamali75
Hi Dears ,
 I have struggle with symbols in Plant 3d (Iso)  and P & ID !!!
After Define new symbol in Project and attend it to an object for Take isometric Draft
unfortunately it's scale doesn't match to other object  and i have to edit  iso again .
also all symbol dimension set according to suggested Dimension  by Manual or native Symbol exist in Data base !!!
please guide me for Solve this issue .
thank you
h_eger
Dear @Mohammadjamali75 ,
Attention:
P&ID symbols have absolutely no influence on the ISO symbols.
Both symbols must be configured for the respective area (P&ID or ISO).
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
kepinski
All object should be made with same units.
Command: dwgunits. Don't use imperial units or you have to rescale all blocks. Have you checked dwg units in *.dwt file ?
Mohammadjamali75
Hi - Firstly i am thankful For ur attention .
secondly : i know that P&ID IS separate From Plant 3d
i can Set P&ID New Symbol  with Originals but in 3d plant, it is impossible  😑😥
Mohammadjamali75
Hi , thank you for attention .
all  Iso object or P & ID object must build in unitless mode and then use scale factor for them
Mohammadjamali75
 This is a sample
Mohammadjamali75
Solution :
have in mind that :
Before start Drawing Symbol Set ur File Unit on [ Unitless]
Secondly : Your Symbol Most has 1.5*1.5 unitless  dimension
Third : Flanges most Drawing in 0.5 unitless Dimension
Fourth: In P&ID Symbols Scale is 10  and 3d plant Iso   Scale is  20
after These u could approve to Suitable Iso Format
