Hi I am in a hot spot i require assistance in editing a off page conector
i have a off page conector that i have to type in a chemical name h2so4 with the 2 and the 4 in subscript
how do i do this
PLEASE HELP!!!
There would be no real way to do this, since the object is based on attributes and isn't behaving like MTEXT box
What you could do is:
Create your offpage connector, connect to DWG as required.
Place an offpage connector in open area, explode it. Now the fields/attributes become editable. Overlap this text over the existing, connected one and you may perform your MTEXT edits and stack the super/subscripts.
Another method would be to create two properties assigned to the Off Page Connector class, under P&ID Class settings, Non Engineering. And call them "Subscript" and "Superscript", string.
Then edit the block for your Off Page Connector, click on the #(. ) define attributes. Place one somewhere, browse to your newly created field.
Make the text size small on this and place it in a spot that would be relevant. (I understand this is a very impractical solution to your issue where it would need to be placed between other characters). Alternatively just type #(TargetObject.Subscript)
