Hi all
Some context: I have added a new endconnection (FO) to my Plant 3D project and am trying to get the ISO according to my wishes. I am trying to make a face seal connection using the Stub-end ISO block to visualize it in 2D.
To visualize this in 3D I want to make a Pipe connect to an Elbow with a Stub End. The stub end would be a SW at the pipe side and a PL at the side of the Elbow.
I have added the FO endconnection to the endcode list in my Plant project. I have also set up the FaceSeal connection as a Simple joint that uses a stub-end to connect FO to PL.
The Skey's are as follows:
Elbow: ELSC
Stub-end: FLSE
I run into two problems:
1) The Stub-end block in the ISO rotates according to flow, I think. Which makes it so it doesn't orient with the flat part to the elbow at all times, can I fix this?
2) The connection to the elbow shows SW's in the ISO, I don't understand why it does this. Can anyone explain why this happens, and how to solve it?
Below some pictures for more clarity.
Dear @arthur.vanhulleHNWW3 ,
Which Plant 3D version do you use?
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Can you please upload the PCF file of this iso for me to test?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Have you tried adding the TYPE=ELBOW,SKEY=ELSC for the content iso symbol? I read that you added the ELSC, but maybe not the type = elbow? Also what happens if you change it to ELSW, I know you don't want socketweld, but does it fix the flipping of the socket?
Hi @George.Endrulat , @h_eger
I have tried another approach by now. I introduced another new endconnection (FOPL). I added the stub-end as a Coupling to my spec with one end FOPL and one end SW. Then I made a simple joint FO to FOPL and a compound joint FO to PL using the coupling I added. This gives a good 3D visual. I also made an Skey for the FO endconnection and put in a new Block in the IsoSymbolStyles.dwg. There are still problems with the ISO however:
1)Whenever I make an ISO, they get split at the couplings.
2) The FO Skey only gets drawn when it's dashed lines
The Skey's are:
Coupling: COFO
Elbow: ELSC
Attached are two PCF files, one where I put everything in the ISO, and one where I only selected the bottom line.
Can you tell me why this happens?
