AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Stub End Symbol is Not Aligned as required.
1 REPLY 1
rafimh2022
134 Views, 1 Reply
Hi All,
Kindly look into the attached image. Stub End Symbol for upside is correctly done but bottom side symbol is 180 Deg. Rotated. Also May i know how to Auto adjust the AnnoRectangle as per the text length? Thanks.
Thanks & Regards,
Rafi.
1 REPLY 1
h_eger
in reply to: rafimh2022
@rafimh2022 ,
Both problems have landed at Autodesk and should be fixed in the next update.
For the first point, only the manual rework helps by adding 180 to the rotation angle of the stub end
For the second point, editing the IsoConfig.xml helps
Check whether the two marked values are also Rectangle and not Rectangle.
This change can be made automatically when opening and closing the project setup.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
