Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I cant find component to setup as Stub end socket welded.
Can someone help me.
Thank You.
Hi
Thank You.
should the stub in with Socket Weld look like?
Regards
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
its like socket welded flange but in this case its only socket welded stub in for LJ flange. its flange adaptor.
1 Flange Socked Weld
2 Flange Socked Weld
3 Pipe 1"
4 Pipe 4"
PipeClass CS150
conectet with Toggle Stub-In
Regards
Hartmut
Hartmut Eger
Senior Engineer
XING | LinkedIn
im sorry but its not stub in, it stub end for LJ flange, its just that this stub end, number 2 on picture is socket welded. Its about PP pipes
http://www.gfps.com/appgate/ecat/common_flow/10006Q/CH/en/109064/109100/109101/131516/index.html
Hartmut Eger
Senior Engineer
XING | LinkedIn
Yes that is it, my only problem is inside Plant 3d how to set it up.
I know how to make BW and PPL stub end but this I cant find apropriate geometry in Plant 3d database.
I want to have all parameters and proper geometry inside model
Just Backup your Defult Connection.XML and consider the attached file
Ahmed Helal
It involves a Fastener in Plant 3D.
Hartmut Eger
Senior Engineer
XING | LinkedIn
yes something like that but I need socketed type.
Something like this one but to have SW end for pipe (this one is BW)
I found it.
Thanks all for help
