Strainer iso symbol error
sagar.ukarde47VQR
sagar.ukarde47VQR
I have added one custom part i.e. Inline Strainer with 4 ports. See below snap (strainer_1.JPG)
Iso symbol created for this....see attached snap (stainer_2.JPG)
and created Isoskey for the same. See attached snap (stainer_3.JPG).
After extracting Isometric, other two ports which is not inline is coming from center of strainer instead of
flange face. See attached snap (stainer_4.JPG)
Please suggest if I miss any step / procedure.
Sagar
You use plantpartconvert?
sagar.ukarde47VQR
Yes I use "plantpartconvert" for making this component.
VinodBalasubramanian
Autodesk Support
Autodesk Support
Can you share the model or the project where you are facing the problem ?
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
sagar.ukarde47VQR
Please find attached model as required.
Regards
Sagar
