Why some objects are blank status ? Bug ?
In the property project, by default it's NEW.
User does not change this value !
Result in bill of material with Report Creator, this materiel is not include and therefore not ordered !!!
Best regards.
Dear @Anonymous,
see Link:
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear Serge,
have you installed the versions 2018 and 2019 side-by-side on one machine? There is an effect which is currently under investigation. Currently if you want to work on version 2018, please, uninstall and re-install update 2018.1.1. Alternatively you can of course uninstall one of these versions.
This can happen if Plant 3D 2018 is installed side-by-side with Plant 3D 2017 of the same language.
There are two possible solutions
or
In this case, just do a clean uninstall and re-install, using this article: http://knowledge.autodesk.com/article/Clean-uninstall-of-AutoCAD-or-verticals
Hello Bernd @Bernd.Gerstenberger,
we recently noticed the same problem. We are using Plant 2017 and 2016 side-by-side in German. So the problem seems to exist generally with parallel installation of older versions?
Best Regards
Steffen
