Spool numbering doesn't follow the flow direction
Vasu27
Vasu27
While generating isometrics, I like to have the spool numbering to be done in the direction of the flow arrow. I tried using the Start Point, and even the "Reverse' option in advanced settings, but nothing works. Is there a way to control the spool numbering direction in isometrics.
Or anyone knows, in which order the spools are numbered?
Vasu
antonio.leonardo
Hi @Vasu27,
The spool number control can only be manually by modeler (user-interface) analysis, this role that you want do not exists at AutoCAD Plant 3D yet; it's exists on PDMS application.
But, if you need to execute this role or if this role impacts your business, you need to develop one Plugin that meet the requirements.
Att,
Antonio Leonardo
Vasu27
@antonio.leonardo, Thanks for the reply.
cynthia.claire.tan
Hello @Vasu27,
It is possible to control the spool number sequence in isometric drawings by assigning a spool number to the 3D model properties. Configure the Iso Style Setup - Spools - Sizing method to 'Use spool number from model' to reflect changes on isometric drawing.
Please refer to this article for more details: Spool numbering from the model
Cynthia Claire Tan
Technical Support Specialist
If my reply was helpful, please like or click the "Accept as Solution" button below (or both).
Cynthia Claire Tan
Global Product Support
Vasu27
@cynthia.claire.tan , thanks, but, I am looking to understand/control the sequencing of the automated spool numbering.
cynthia.claire.tan
Hello @Vasu27 ,
Thank you for the clarification. Feel free to log this enhancement to Autodesk Idea Station (AutoCAD Plant 3D / P&ID Ideas)
Cynthia Claire Tan
Cynthia Claire Tan
