AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Split Isos by Area - ERROR - Failed to sort the data table.
4 REPLIES 4
George.Endrulat
1000 Views, 4 Replies
We are splitting isometrics by 3D Model Drawing Area via:
    <PrefixModelProperties>
      <!-- Model property -->
      <!-- 'Name': (string); The model property name. -->
      <!-- 'Delimiter': (string); The delimiter. -->
      <ModelProperty Name="AREA" Delimiter="-" />
      <ModelProperty Name="PIPELINE-REFERENCE" Delimiter="-" />
    </PrefixModelProperties>
For iso drawing name and file name.
If we don't receive the error:
In the IsoCreationLog.txt then it splits the iso just fine into areas i.e. A01-123-1, A05-123-2
If we do receive the error then all the areas are set to the same i.e.  A05-123-1, A05-123-2
How do I rectify the error:
Where can I look up what the error means?  Is there an isometric error reference?  Does anyone have a solution for this error?
Additionally there are no other errors or warnings.
George
If my post offers a solution, please click "Accept as Solution"
Labels (1)
4 REPLIES 4
h_eger
in reply to: George.Endrulat
as already written in the previous post.
It only works if you include the area in your pipe number.
Your pipeline does not know in which area it is located.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
George.Endrulat
in reply to: h_eger
That's just plainly false.  It does work if we don't receive the data table error and it works well.  We have generated hundreds and soon to be thousands of isos using this method, we just have a few lines where we get the error.
I didn't ask for a critique of the method of splitting by area, I asked for details on the error.
If you don't know please don't reply with information not pertaining to the question.
George
h_eger
Dear @George.Endrulat ,
all is well.
We wish you continued success with Plant 3D
Hartmut Eger
Senior Engineer
XING | LinkedIn
Hello.
I don't know if it will help, but I used to get that error and it was solved by removing the break points from 3D.
Greetings.
