We want to be able to show a dimension for example: 24'-0"
What generates in the Iso is 24'...............is there a setting for this?
Solved by dave.wolfe. Go to Solution.
Modify the dimension style in your iso template.
How do you get it to show inches under 1'-0" instead of 2'-0" I would like it to read 1'-7" instead of 19"
Edit the isoconfig.xml file as shown. You'll need to change this for every Theme.
