Selection lists for 3D class definitions missing
robbie.gray
robbie.gray
I noticed this problem when I tried to add insulation to my pipes and couldnt, even in overide mode i couldnt see the drop down list for options. In project setup i noticed that my selection lists for 3D class definitions seem to be gone! Can someone please help me get these properties back? I also noticed other things that were missing that shouldnt be like color assignments to diameter of pipes.
h_eger
Dear @robbie.gray ,
I can not say what happened to your project and its settings but from my point of view it is broken!
Not only a selection list is missing but ALL!!!
Can you go back to a backup and check if this project still has selection lists?
otherwise the only way is to create a new project.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
robbie.gray
Oh no! I do not know what happened but my backups also have this issue. Hopefully someone else has a solution as I cannot justify restarting this project. I would much rather reenter the selection lists manually at this point.
robbie.gray
What is odd is that my P&ID selection lists are perfectly in tact...
h_eger
You can use Project Compare with Plant 3D 2022 to get the missing selection lists back.
I've never done it but if you're lucky it works.
Hartmut Eger
Senior Engineer
XING | LinkedIn
robbie.gray
Wow Thank you Hartmut! This worked perfectly...what a great feature. I can even continue working in 2021 even though the compare function was in 2022. I really appreciate the help, thanks again.
GCM_S_Hotte
I used the compare feature to bring picklist from an other project. The list are there but not shown in the class parent.
Is there a way to make them shown?
SH
