Secondary Supports
Secondary Supports
Secondary Supports
Hi Friends
              This Antony From chennai, im working here as Piping Design Engineer as well as Autocad Plant 3d Administrator.
I have difficulties to add secondary supports ( like structural members for hanging L-type) to primary supports and how can i take the Bom for the Secondary Supports.
            Please share your knowledge if you have any idea about above said.
Thanks & Regards
S.Antony Heruldos
paragnewe
have you got any luck to fix this issue ?
-Regards
Prag
ken.fauver
You will need to convert the structural member to a support (first explode it back down to a 3D Solid and Layer is "0" and Color is "Byblock"). Then you can connect the secondary support using the PLANTSUPPORTSONSUPPORTS command.
