AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Scaling the size of the OPC "Not Connected" Flag
8 REPLIES 8
Message 1 of 9
702 Views, 8 Replies
Hello All,
I've been struggling to find where in the project manager to edit this, but long story short: I was given a project in a "weird" scale, so I was able to scale all the objects back down to normal. However, as I begin to input OPC's, I find that the error symbol did not scale down as well (see attached).
The picture shows the standard size for my OPC flag, as well as the unfortunately LARGE error flag that hides the OPC underneath.
Is there a block solely for the error symbol?
Thanks for any help,
-Joe
8 REPLIES 8
Message 2 of 9
h_eger
Hello Joe,
was the initial project PIP or ISA (imperial)?
If the target Prokjet DIN, ISO etc. (metric)?
It is not possible to scale the bitmaps.
We have the problem in the other direction DIN -> PIP the bitmaps are very small Smiley Frustrated
I know of no solution of the problem.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 9
in reply to: h_eger
Hartmut,
Both projects were PIP, but conveniently enough, the flag is scaled to ~25.4 times as large as I expect it to! So there's definitely a mm to in exchange somewhere in there.
I assumed the graphic would be stored somewhere in the Autodesk file settings somewhere so I could rescale it, but I've had no luck either.
Message 4 of 9
h_eger
Sorry but I have no idea.
you can attach this drawing?
so we can test better in order to find the problem.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 9
in reply to: h_eger
I've attached a test drawing I've been playing around with. It has an OPC connected to a line, with the "not connected" image covering up the OPC. It also has just a blank OPC not connected to anything to show the actual block size.
I suspect the drawing alone may not show any issues (if it does, then great). However, I am unsure I can post the entire project at this time. If it comes down to it, I may need to set up a new project and then copy all the drawings in.
Message 6 of 9
h_eger
Hi Joe,
so now it gets complicated
For me it is no problem with Plant 2016 Ext 1 SP2.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 7 of 9
in reply to: h_eger
So, it's definitely a project setting, not drawing-specific. When I open the drawing OUTSIDE of its project, no problem occurs.
This leads to one of two options:
1. The hardest option, figure out the actual root of the problem.
2. Are there any reprecussions to starting a new project and copying my drawings over to the new one? In theory it seems like the easy fix, but I don't want to lose a bunch of data by copying drawings over.
Message 8 of 9
h_eger
Point 2. It is no problem to take the solution to create a new project and copy all the drawings in the new project.
When configuring both projects must be the same otherwise it does not work with the copy of the drawings.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 9 of 9
in reply to: h_eger
Hartmut,
Thanks for keeping up on the issue.
I ended up creating a new project and copying the drawings. However, to keep everything in scale, I did have to change from metric to imperial units. (It does not affect me much either way for P&ID drawings).
Technology Administrators
AutoCAD Beta
