Has anyone built a catalog of SAE Code 61 & 62 flanges that they would like to share?
Solved by rkreiss375. Go to Solution.
Dear @rkreiss375,
Catalog of SAE Code 61 & 62 flanges are also not available in the Autodesk APP Store.
Since you can only hope that there are users who have created the catalog already otherwise you must create this yourself.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Here is a file with blocks of 1/2" thru 3", flat socket weld, deep socket weld, butt weld, in both Code 61 and Code 62.
46 blocks in total, all have been "plantpartconvert" with ports added., ready to use as a custom part.
Here in the attachment is the catalog of SAE flanges.
actually SAE flanges include a group of different types, such as SAE split flanges, SAE flange clamps, SAE Socket weld flanges, SAE butt weld flanges, Screw-in SAE flanges (BSPP, NPT threaded SAE flanges) and SAE blind flanges, and so on.
The above group of SAE flanges are included in the attached catalogs all.
Code 61 flange and code 62 flange are designed as per standard ISO 6162-1 and ISO 6162-2, they are conformed to standard SAE J518, so they are well known as SAE flanges also.
As a professional China SAE flange manufacturer, we have all types and full size range of SAE flange code 61/62, but our catalog is too big in size to upload to the forum. People who are interested, can visit our website (http://flanges-pipe.com) to download the catalogs and data sheets of the SAE code 61 & code 62 flanges.
