RPC_E_SERVERFAULT error message when exporting
Message 1 of 9
I have a customer who when exporting a project as an .xls gets the error message
"The server threw an exception. (Exception from HRESULT: 0x80010105(RPC_E_SERVERFAULT))"
He gets this when exporting to the server and local machine, they have got a new server recently but can't see what is causing this issue
Software Autocad plant 3d 2016
Replies (8)
Message 2 of 9
h_eger
Hi @Anonymous,
is it a Microsoft SQL Server in collaboration with Autodesk AutoCAD Plant 3D 2016?
Are the server access rights again completely and correctly set up?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 9
Dan.Scales
Hi @Anonymous,
Is Plant 3D 2016 installed in Windows 10?
Error-when-exporting-from-the-data-manager-to-Excel-in-AutoCAD-Plant-3D-2016-on-Windows-10
Dan
Dan Scales
Message 4 of 9
borut.orel
Hi everyone!
I have the same exact message when I try to export instrumentation or equipment lists. I recently moved the project from one partition to another. Before the export option worked just fine. Could this be the problem?
Please help me!
Thank you and kind regards!
Borut Orel
Message 5 of 9
borut.orel
I forgot to mention:
i am useing ACAD P&ID 2017 and windows 10.
could there be a problem with this??
Message 6 of 9
cyklosarin
I'm struggling with the same problem. Closing to the end of the project, some data need to be exported to the third party and bellow attached error appears:
I have installed Autocad Plant 2017 with 2017.1 update.  Does someone have similar problem?
Best regards
Dominik
Message 7 of 9
h_eger
Dear @cyklosarin,
please give a detailed description of the work steps.
I can not do anything with the error message.
We need the work steps up to the error message.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 9
Ruffy85
RPC_E_SERVERFAULT means that the out-of-process COM server threw a structured (Win32)exception
Try to reinstall the Client
Message 9 of 9
cyklosarin
I think the worksteps I made are very typical:
1 - open data manager
2 - right click on object group - > export
3 - OK (I tried all options not only marked on screenshot bellow)
4 - error shows up
My IT manager reinstalled windows and other software so now it is working. But I'm curious why this error appears while I have autocad plant 2017.1 installed. According to the autodesk  community database on this version it should work.
Best regards
Dominik
