AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Routing pipe uses a dynamic UCS, how do I shut this off?
9 REPLIES 9
Message 1 of 10
WPerciful
2837 Views, 9 Replies
As you’re routine piping in AutoCAD Plant 3D the UCS is constantly changing itself as you route. Is there a way to disable this?  A dynamic UCS during routing renders point filters useless.  This feature is an endless frustration.
I do not wish to employ another method for routine pipe to compensate for the software rendering point filters, during routing, useless. I’ve been routing pipe and then stopping to realigning the pipe with point filters.
Wayne Perciful
Founder | Perciful Consulting LLC
Perciful Consulting
9 REPLIES 9
Message 2 of 10
jabowabo
in reply to: WPerciful
Try turning the compass feature off.
Message 3 of 10
WPerciful
in reply to: jabowabo
That doesn't fix the issue.  If you're in a front view and set the UCS to current the cube will say Top.  But the moment you begin to route it changes.
Wayne Perciful
Perciful Consulting
Message 4 of 10
jabowabo
Maybe I'm missing something - appears to work for me.
Message 5 of 10
WPerciful
The fist screen shot is prior to routing pipe.  The second is once you've begun routing pipe.  Notice the UCS (nave cube) changes the moment that routing begins.  It continues to adjust the UCS while routing.  This means if I'm routing to a tie point I need to route, then stop then adjust the routed line using the point filters after I've either deleted segments of the route or locked segments of the route.
Wayne Perciful
Perciful Consulting
Message 6 of 10
jabowabo
Modify your view cube settings as shown:
Message 7 of 10
WPerciful
Might you know the system variable for that setting?
Wayne Perciful
Perciful Consulting
Message 8 of 10
jabowabo
NAVVCUBEORIENT
Message 9 of 10
hean117
Hmmm, this setting doen't do it for me. I still have the frustration over the coordinate system changing when routing. Any other ideas?
Message 10 of 10
Thanks, so there is no solution but only frustration 🙂 🙂
Hope they fix this in further versions. Thansk anyway and wish you a nice weekend.
