AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Route Multiple Pipes at Once Plant3d
1 REPLY 1
rigginc
432 Views, 1 Reply
Is there a way to route multiple pipes at once.  If not, is there an easy way to copy the pipe run and offset the entire run by say 2'-0".
1 REPLY 1
Dan.Scales
in reply to: rigginc
One way would be to use the "Line to Pipe" command and select multiple lines to convert.
You could also try drawing an Mline with the required number of lines, explode it and convert them to pipes.
Hope this helps.
Dan
Dan Scales
Technology Administrators
AutoCAD Beta
