ROTATION OF CUSTOM ACTUATOR independently from valve.
I WANNA KNOW HOW TO ROTATE A CUSTOM ACTUATOR(BLOCK BASED) INDEPENDENTLY FROM VALVE(STANDARD VALVE)
h_eger
No this function is not available in Plant 3D.
The only solution is to create 2 valves and connect the actuators to the valve body once with 0 degrees and once with 90 degrees
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jw7018
Is it possible to create block based valve and attach an out of the box actuator ? Or even a custom actuator so it could be rotated independently ?
h_eger
Dear @jw7018 ,
No, it is not possible to turn the actuator separately from the valve body
Hartmut Eger
Senior Engineer
XING | LinkedIn
Teddy_Bernardo
You can do this by having additional actuator of the valve. I have tried to use this and it solve the problem somehow. This can take additional work.
Teddy_Bernardo_0-1692143143378.pngTeddy_Bernardo_1-1692143225206.pngTeddy_Bernardo_2-1692143256538.pngTeddy_Bernardo_3-1692143279973.png
