Hi Folks
Brand new to forum. Sorry if this seems its been asked before but my situation has some unique differences. I completed a P3D project (without connected P&ID data) and proceeded to copy the top level folder in windows and paste to a temp storage drive. This retained all project data and folder structure including project xml & associated xml's and specs & catalogues. Unfortunately at the time I didn't realize I could move or copy a P3D project so didn't copy the associated databases from SQL Server Express.
I'd like to know if its still possible to create a new P3D project based on above partially copied project above. As a bear minimum I'd like to be able to reuse the above existing project spec?
Any suggestions appreciated
Yes it is possible, I was just in doubt if you copied the dcf files that are the local banks of the project and that are in the project folder. If you have copied, I see two options:
1- You can edit the configuration xml's to make it a SQLite project and then use the plant 3d tool to return to a SQLServer project.
2- If you do not have dcf banks, you can try to import the dwg for a new project, with the same structure as the previous one.
Thanks Mateus
I have 5 dcf files located in the project root folder see below?
Iso.dcf
Misc.dcf
Ortho.dcf
Piping.dcf
ProcessPower.dcf
Are these the files you refer too?
Which configuration xml's are you referring to and how might one edit these files to make SQLite project? This is exactly what I'd like to do. Thanks again
Tried to open project.xml and received following error msg:
This does make sense since the SQL server express instance was not copied.
Seems without the instance (or project backup or copy of it) there is no way to either 1) copy from existing project.xml or open existing project.xml?
@Anonymous , I did this procedure on a SQL Server project, but I used the vault, so that could have been it.
But then try the 2nd option, I created a project like the previous one and copy the dwg's to within the project
create the new project using the old project template file and copy all the dwg form old to new.
