Retain RevClouds after data import
Is there a way to retain the revision clouds after importing data. If would be great to print them. Thanks.
quentin.contreras
Autodesk Support
Autodesk Support
@Anonymous I am not really sure on your workflow with RevClouds. Could you provide some additional detail and any screen captures that might help to visualize what you want.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Thank you for your reply. When importing data from a spreadsheet to update P&ID's, revision bubbles appear around the elements that were updated. But they are removed when you accept the changes. Is there a way to retain those bubbles similar to when a drawing is verified while opening it? Thanks.
quentin.contreras
Autodesk Support
Autodesk Support
@Anonymous unfortunately, this appears not to be an editable overlay with the import and verification process in AutoCAD P&ID.
Would recommend post this to the AutoCAD Plant 3D/P&ID Ideas forum for consideration in a future release of Plant 3D/P&ID.
Quentin Contreras
david.manningXME8A
