Report Creator: Pipe and Fittings weights
Ray_K
Ray_K
I am trying to generate Pipes and Fitting weights using Report Creator. I noticed that some pipes has wrong weights even the Linear weights, cut length and weights values are correctly shown on Plant 3D Properties. See screenshot below.
I used Engineering Items_Weight
jabowabo
Summary should be set to 'Group' if you want it added up.
Ray_K
@jabowabo
I just need for individual component item. Not sure why some components showing wrong weight information. I attached rcf template. Hope you have time to check where did it go wrong.
jabowabo
You will need to add a sort criteria for EVERY column that you do not want to group - including weight if you do not want it added up.
