I have a problem when converting pipe units from mm to m in Report Creator. I follow the instructions from the autodesk website (https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...) , but all other material quantities change to 1. Am I still missing something in the expression?
Solved by jabowabo. Go to Solution.
dear @a.reuterNT4CE ,
I don't quite understand the question but ONLY the pipe lengths are changed from mm to m, your elbows or other components are counted as pieces.
Addendum:
Would you please make sure that the spaces of your expressions are on the right side!
With this it works
Iif(IsNullOrEmpty([Pipe_CutLength]), 1, Round([Pipe_CutLength]/1000, 2))
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
