- Mute
- Permalink
- Report
Overall, The BOM looks fairly good for what I need it for. I have it print to excel for editing, it's easier than PDF.
The issues that pop up that I am unsure on how to fix.
- Quantity of pipe is in inches - foot inch would be a better format ( and meter millimeter for metric )
- The extra lines between each line item is really annoying, not sure how to remove that. If I shrink the distance in the report designer it starts to cut off the text in the report, an making it larger makes each line item further apart.
- The blank Type: - is structural members, and so is the count. In this particular BOM it's ledger angles. I am trying to use the structure tab instead of making each ledger angle a separate piece of equipment - which is time consuming. When I try to add in another line item for the structural component it doubles the spaces between each line item for the entire BOM.
This isn't the full list in the BOM - I deleted a bunch of lines to make it shorter and easier to display.
Any help would be appreciated, It has been a long time since I tried editing with the report creator and I'm getting a little frustrated and figured asking for help would be the best bet.
Hey, if I'm doing something stupid or silly - just let me know. I'm more than happy to have this made better.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Link copied
