AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Report creator 2016 cant open database
3 REPLIES 3
DGRL
354 Views, 3 Replies
DGRL
Dear forum members,
I have a project in Plant 3D 2016 and in Plant 3D it is opening just fine
When we open the project in report creator 2016 we get an error
According report creator the ProcessPower.dcf could not be opened because it cant be found
ProcessPower.dcf is present not read-only and again the project opens just fine in P3D
See error log
Type: Autodesk.ProcessPower.ReportCreatorUtils.ReportCreatorUtilsException
Message: The database P:\Acad\P3D\project templates\Backups\2016\Empty Metric Project\ProcessPower.dcf could not be opened.
Stack trace:
   at Autodesk.ProcessPower.ReportCreatorUtils.Database.PlantDatabase..ctor(String databaseFileName, ICollection`1 databaseFilesToAttach, StandardType stdType, SignInFunc siFunc, PlantProject plantPrj)
   at Autodesk.ProcessPower.ReportCreatorUtils.Project.PlantProject..ctor(String xmlProjectFile, SignInFunc siFunc)
   at Autodesk.ProcessPower.ReportCreator.Manager.SetCurrentProject(String projectFile)
   at Autodesk.ProcessPower.ReportCreator.MainForm.OnProjectComboBox_SelectionChangeCommitted(Object sender, EventArgs e)
Inner exception:
Type: System.IO.FileNotFoundException
Message: The file "P:\Acad\P3D\project templates\Backups\2016\Empty Metric Project\ProcessPower.dcf" was not found.
Stack trace:
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Dear forum members,
See error log
Stack trace:
Inner exception:
Stack trace:
Kind Regards
3 REPLIES 3
jabowabo
in reply to: DGRL
jabowabo
You show 'Empty Metric Project 2016' in File Explorer. Try to re-open the project.xml from the correct location.
DGRL
in reply to: jabowabo
DGRL
@jabowabo
The project xml had wrong path in it lol
I changed the project.xml and working fine now
Weird though that the project is opening fine in Plant 3D from the same location.
Kind Regards
@jabowabo
Kind Regards
DGRL
in reply to: DGRL
DGRL
@jabowabo
Funny things happens when you cut and paste a project
The project.xml will not be updated (DUH)
When you open project setup the project will load and open
When you open the same project in report creator this error will popup
(it is an SQLite project)
Kind Regards
@jabowabo
Kind Regards
