AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Removing small bore valve and nipple dimensions, connected on Orifice flange SW/THD ports
1 REPLY 1
jose.guerraQPHUG
184 Views, 1 Reply
Hello community.
Does somebody knows how to remove the valve and nipple dimension located on orifice flange (SW/THD ports) on isometrics drawing?. Those dimension is part of my details, i don't want to show it on the iso because is causing a mess drawing. Also, to remove the spool number on it because is duplicated. Thanks in advance for your help.
1 REPLY 1
(Edited, that solution is easy on Plant3D 2023, I tried on 2022 and the interface is poorer)
Try on project setup, isometric DWG settings, dimensions
What to dimension itens.
You also can changes the Themes options: default, continuation. existing, fitting and smal bore options.
Technology Administrators
AutoCAD Beta
