"Part Category" importance in Catalog families
fatherof3
fatherof3
How critical is the property "Part Category"? Is it used in catalog parts for anything other than being able to apply one of the "Common Filters" in the Spec Editor?
h_eger
Part Category is harcoded and only filtering of all parts in your catalog
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
fatherof3
Thank you, Harmut.
I was copying parts from a catalog to a "temporary spec", then exporting to catalog builder. This property was not being carried over into the excel file, although the column exists in the spreadsheet. Subsequently, when I used the "Build Catalog" command to bring these parts back in to my catalog, the "Part Category" property was blank.
I've since switched my workflow, and now copy parts to a "temporary catalog". This seems to keep the "Part Category" data intact.
Even going back into the spreadsheet and filling in the "PartCategory" column in excel, then rebuilding the part to the catalog, the filter still ignores it and acts as thought that property is empty.
h_eger
I tested this procedure.
If an error, when the catalog create in CatalogGenerator.
Please contact Autodesk Support.
Hartmut Eger
Senior Engineer
XING | LinkedIn
