Is it possible to change some in to the title block:
- Drawn by; doesn't fill in automaticlly. And would like to fill in automaticlly to name for example: F. Lastname
- Creation date; is now 25-JAN-24, and would like it to be 25-01-2024.
Thank you in advance!
Solved by h_eger. Go to Solution.
Dear @GKR2023 ,
please mark with a cross:
P&ID
Ortho
Isometric
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear @GKR2023 ,
You can use the iso configuration for the date. Unfortunately, we have no influence on the separators.
I always use the "P3d Line Group" for the name
create a string "NAME"
Now add the Isometric header attribute and save. Execute ATTSYNCH on the title block so that the attribute is also applied to the iso.
Hartmut Eger
Senior Engineer
XING | LinkedIn
It now checks for the AuthorLGP.
And i tried also your method. But it still won't show the name for some reason
