PRV not showing in BOM or drawing area
dmgraves
dmgraves
PRV's are not populating the bom nor are they identifying in the drawing.
dmgraves
Great!  Halfway there!  Populated the BOM but no "balloon"  in the drawing field.
jabowabo
You'll need to create an AnnotationScheme for instruments. Here's a sample - you'll need to change it per your environment. You need an AnnotationStyle and Filter to go along with it.
<ComponentScheme Name="InstrumentTag" AnnotationStyle="InstrumentBubble" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AlwaysNonArrowed" Filter="TaggedInstrument" Fields="InstrumentTagAnno" />
You may can add these via the GUI as well, put I don't use it so can't advise how.
dmgraves
Awesome!  Thank you!  Much appreciated!
