Property Dialog Box STRING TEXT
Dear all,
If I am creating new properties for P&ID Class Definitions
(Project Setup/P&ID DWG Settings/ P&ID Class Definitions/Non Engineering Items/Flag/Equipment_List)
Then i have few options, the option to insert Text (String) is limited to 255 characters, I know this from checking the database structure with the program DB Browser (SQLite). If I go to this field, it's configured as VarChar(255), however I want to use this field to enter long texts with Equipments descriptions, tags, notes, etc.
Is there any way to change this field and convert it into "TEXT" instead of VarChar(255)
Health for you all!!
h_eger
Dear @Anonymous ,
you have to make the following changes in the DB table PNPProperties.
maximum length in a data field is 65535 (64K-1)
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear H. Eger,
Thanks a lot for the answer, it does help and therefore I will be able to save tons of workhours that I can now invest in other works!!!!
MUCHISIMAS GRACIAS!!!!
Btw,
Does the programme SQLite Expert Professional remain for free after the 40 days trial?
If not, is there an alternative to it?
Best Regards!
h_eger
Dear @Anonymous ,
SQLite Expert Personal is also available for this work and is free.
http://www.sqliteexpert.com/download.html
The professional version costs $ 99, -
http://www.sqliteexpert.com/order.html
Hartmut Eger
Senior Engineer
XING | LinkedIn
