I want to setup a company standard project where we use some of the PIP and some of the ISA symbols. I found that I need to setup two projects, one PIP and the other ISA, to get the projSymbolStyle.dwg for each symbol style. The question arises in that I used the Default Project template to create both projects. I have been assuming that the two setups would use the same projSymbolStyle.dwg, but it seems they don't. When I look in the Default projSymbolStyle.dwg, it appears to be the PIP. So, in Project Setup, and you pick the ISA symbol set, where are these symbols stored and how does the Default Project setup get them into the new project's projSymbolStyle.dwg? I know, it is just a logistic question, but I am very curious.
