AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
project settings for metric to imperial
2 REPLIES 2
1284 Views, 2 Replies
 how can I change the project unit from imperial to mixed metric?  command? Thanks
2 REPLIES 2
h_eger
Dear @Anonymous,
How to change the unit of an AutoCAD Plant 3D project after the project creation
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
mcarlton71
in reply to: h_eger
I have created a backup copy of my project template and changed it to mixed metric. things seem to be behaving as expected, I can utilize my standard imperial pipe specs while laying all of my equipment and bays out in a true metric fashion. Orthographics are working, however, the isometrics keep failing when I try to run them. I can not figure out if there is a setting I need to change that is buried in some xml file somewhere? I would really hate to have to recreate the isometric settings as this was a huge task to begin with in customizing.
