Producing Isometrics using a UCS, not WCS
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So we've just begun a project involving piping between two buildings, with a consulatant responsible for building design.
The buildings have been designed and modelled to real world coordinates and are correctly located in the WCS system with matching ID points. The buildings are constantly updated and sent to us to include in our model and work to.
Now in the past we've mainly worked on in office projects where we could discuss and set out of XREF's and adjust accordingly, this isn't an option for this project and we need to work with the models provided without adjusting there location in the cad file (as we'd be forever moving them every time we receive an updated copy)
Modelling pipe is no problem as we can set up a UCS to the plant datum, which runs perpendicular/parallel to the buildings. But producing isometrics is inconvenient as we're left with skewed isometrics and pipe angle hatches all over the drawing. Ideally we want to produce isometrics to the plant datum so the pipe appears on the isometrics running North to South, East to West.
Usually this wouldn't be a problem as we would set up our WCS as the plant datum/coordinate system and have a separate UCS for measuring real-world coordinates. But in this situation our piping will be situated to real world cardinal directions.
Whilst we can produce isometrics by rotating the model this isn't efficient and produces incorrect coordinates on the isometrics. Ultimately what I want to know is if there is a way to produce isometrics off a UCS, not the WCS?
