AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Problems with the ports of an custom element in Isometric
4 REPLIES 4
jorge_ortegaH5P2C
333 Views, 4 Replies
Hi everyone!
I have a problem with a Iso symbol block of an element that was created to appear correctly in the isometric.
The Iso symbol block was made by adding the ports shown in the following image:
But it turns out that when the isometric is pulled out, the ports of the 1/2” lines are connecting in the center of the element and not where it was defined in the Iso symbol block.
I would appreciate your help!
4 REPLIES 4
h_eger
in reply to: jorge_ortegaH5P2C
@jorge_ortegaH5P2C ,
In which document did you find the instructions that your Iso symbol works like this?
The PCF specification does not allow the port connections as you have created them.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hello @jorge_ortegaH5P2C
Here is the setting that I defined for the creation of the isometric symbol
And here is the isometric output result on a component having 2 main ports and 2 secondary ports
Depending on the "TYPE" category you define this will work or not.
Here are the types that work, I haven't tested it all.
FLANGE-BLIND
FLANGE-REDUCING-CONCENTRIC
== French ==
Voici le paramétrage que j'ai défini au niveau de la création du symbole isométrique
Et voici le résultat en sortie isométrique sur un composant ayant 2 ports principaux et 2 ports secondaires
Selon la catégorie du "TYPE" que vous définissez cela fonctionnera ou pas.
Voici les types qui fonctionnent, je ne l'ai pas tous testé.
FLANGE-BLIND
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Hello @DVaquand
I tried what you indicate but it did not work.
I changed the Type category to Flange-Blind but it didn't work, still the same.
I don't know what it could be, I followed the steps in the De-Mystifying AutoCAD Plant 3D Isometrics manual to create the block for the isometric.
hello @jorge_ortegaH5P2C
See video
Cordialement
Dominique VAQUAND
www.dovaq.fr
