AutoCAD Plant 3D Forum
Problem on isometrics with slope dimensioning
3 REPLIES 3
556 Views, 3 Replies
Hi!
i have a problem in Plant 3D 2016 ext1 sp2.
when i have a sloped pipe which is running on the X axle. both dimensions for height and lenght are the same on the isometric.
does anybody know how to fix it? when the pipe runs on the Y axle it works.
i have  testet with a new project and everything on default settings too. but the problem is the same.
hope you can understand my problem. you can see it in the attachment.
3 REPLIES 3
h_eger
Hallo Mario,
es langt wenn du deine Frage in einem der beiden Forums absetzt.
ich antworte auch nur einmal 🙂
Gruß
Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
Hi Hartmut!
😄 danke.
Hi!
just to let you know. if anybody has the same problem. i got an inofficial hotfix from autodesk support.
kind regards Mario
