AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Port Priority
2 REPLIES 2
400 Views, 2 Replies
Port Priority
Im trying to use a custom part that has three ports. One THDM and two THDF.  When I go to insert I would like for the Male port to be the insert port.  As i have it now it snaps to the THDF and I get an error that it can not match THDF to THDF.  No crap, thats why i want to use the THDM port.  Can anyone help with this?
Thamks
2 REPLIES 2
h_eger
when inserting the parts, you switch by pressing CTRL the port.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
bgerig
Also when you run the plantpartconvert command the first port you add becomes the insertion port. I would start back at the block (just AutoCAD block with no ports assigned), run the plantpartconvert>add, choose the THDM port first, than add the other to ports, exit, bring the block back into the custom parts editor or catalog, then get it back into the model and you should be inserting based off the first port you choose durning the plantpartconvert command. The order you put ports on decides which is Port 1 (insertion port), port 2, port 3, etc.
Brady Gerig
Shambaugh and Son
