AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plantpartconvert acting up
2 REPLIES 2
cad-pc3EHPU7
153 Views, 2 Replies
Hi guys,
This is a multi step question. Im having a problem with converting the block from this step file into a custom part. No matter how I apply my port connections, Once I create custom part the ports end up very close to the center of the valve. No combination of editing the port placement in plantpartconvert, saving, and reopening has changed the results.
Secondly, once I am able to successfully position my ports, how should I define the valve so that it accepts RF flanges without requiring Gaskets?
Thank you for your time,
John Paul Ho
Junior CAD Designer.
2 REPLIES 2
quan_hm
in reply to: cad-pc3EHPU7
Hi
As I check when import the step file it was scale down to 1/25.4. You need to scale up to x25.4 before adding the port.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
quan_hm
Your other question,
you need to go to connection setup and uncheck gasket
