AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PlantCustomParts: No part type in the form available
2 REPLIES 2
506 Views, 2 Replies
Hello when I open the form with the command "PlantCustomParts" I can not select a part type because the combobox is empty. The comboboxes of nominal diameter an connection type too. (please see the attachm.) (The specs for custom parts and placeholders are in the project spec path) Any ideas?
2 REPLIES 2
h_eger
Dear @Anonymous ,
unfortunately, I can not reconstruct your problem.
Everything works for me.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
...my failure, I copied the files CustomParts* later to the spec folder, but did not add them to the project with right-click on spec folder in the project browser...
