AutoCAD Plant 3D Forum
Plant3d python script
1 REPLY 1
thamilv91
338 Views, 1 Reply
I created a custom Python script. I created a custom scripts path with .py, .pyc, .png, and .XML files. I also created other files using another workstation. Now, I am trying to remove only the .py file, but it's not working. The catalog and spec files are not affected. How can I solve this problem, and is there any solution to create a new catalog build?
Thank you
Tags (3)
Labels (1)
1 REPLY 1
matt.worland
in reply to: thamilv91
I don't believe you can remove the py files. When you run PlantRegisterCustomScripts, it creates the pyc, and other files, but that doesn't mean, the py file can be removed.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
