Plant3D file error "the file exists"
kgallagherCGHDN
kgallagherCGHDN
We have 1 plant 3D user that had the error "The File Exists" about a month back. it was fixed by rebuilding the profile. this is not an optimal fix, the error has returned. does anyone know a better way to fix this?  has anyone else seen this issue or know the cause? thenks
h_eger
Dear @kgallagherCGHDN ,
I had the same problem and resetting the AutoCAD profile helped. It was about 3 months ago but I haven't had any problems since then.
https://knowledge.autodesk.com/support/autocad-plant-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
kgallagherCGHDN
I have tried this earlier today. unfortunatly it did not work. unless i missed something.
