AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plant3d centerline scale
5 REPLIES 5
1073 Views, 5 Replies
Is there a way to change the centerline scale of the blocks generated in the viewport from the 3d model.
5 REPLIES 5
Tomislav.Golubovic
You can change the linetype in the template file, or in the drawing itself, type in LTSCALE and change it to something higher or smaller to change the scale of the linetype. Note - that will change the linetype scale of ALL the linetypes. If you only want to change the centreline, then you'll have to do it in the template, JUST for the centreline.
in reply to: Tomislav.Golubovic
Hello Tomislav,
Thank you for your reply.
As you said LTscale changes scale of all the lines. But how to change scale of the already generated centerlines. Also I havent found where a how adjust the scale of lines in the template.
Tomislav.Golubovic
LTSCALE on an already created drawing should change the scale regardless.
The Ortho Setup is where you change the Ortho Template. In there you can setup the layers and linetypes for the elements.
Hello Tomislav,
I am aware of all the things previously described but your last reply reflects on the way of changing the belonging layers and line type in the template.
I have it all arranged, and all my viewport layers are correctly adjusted (linetype and color), but since on the same layout I have the 1:100 viewport and 1:10 viepowert my "centerline display" doesnt look the same in both viewports (i.e. my centerlines is displayed as a contionuous line in 1:10 viewport).
Best regards
Tomislav.Golubovic
