is there a way to easily change the symbol for lines when i want to substitute it?
Greetz
Solved by DVaquand. Go to Solution.
Solved by h_eger. Go to Solution.
Unfortunately not.
We have no possibility to change this in the substitution list.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Thanks, @h_eger for your answer!
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community
The solution is that there is no solution :D.
Is there a way that autodesk make this possible to change the symbol for lines via "GraphicalStyleName"?
Hello
Sorry for my English, which I don't speak and whose post has been translated with google Translator
Customization of the P&ID symbol substitution palette is possible.
Here is a screencast
You can read my "TUYAU 39" technical note in French which explains the whole process
https://dovaq.fr/notes-techniques/
== French ==
La personnalisation de la palette de substitution des symboles P&ID est possible.
Vous pouvez lire ma note technique "TUYAU 39" qui explique tout le processus
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Dear @DVaquand ,
Thank you for the perfect hack for the addition of the SubstitutionPalettes.xml.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Yes thats the solution i worked with, thx for sharing that with the rest. The Point is, that this is very user unfriendly and when you change something in the project properties the SubstitutionPalettes.xml sometimes gets overwrite :/.
btw. you can also add "dummysymbols" in the projSymbolStyle.dwg, then copy the "class link" in the SubstitutionPalettes.xml, but i think autodesk should solve this better
This is exactly what I have been looking for!
I followed the links and was able to print out the notes, but not able to have them translated into English (PDF). The video is also in French... does anyone know if this is available in English? and where it can be found?
Thank You!
Barbara
Dear @Barbara.Davis ,
no unfortunately the video is not available in English
Hartmut Eger
Senior Engineer
XING | LinkedIn
Here is the English translation of the notes, PDF... hope this helps someone!
