Plant 3D steel moves location when adjusting length with grips.
webtech
webtech
Does anyone else have this issue?  When dragging struct steel with the grip to a reference point (near, end , intersection...) the steel changes location in the mdel. Does a solution exist? It seems there is a glitch in the software (rel 2024).  Does not occur in rel 2022.
Thank you!
lauri_barnhart
Hi @webtech,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
Michiel.Valcke
2024 has been a while for me, and I haven't got it installed right now so I can't test to recreate the issue. But it does seem vaguely familiar as a bug that was in that version. If it was, it certainly got fixed. Try to install all available updates for the 2024 version or try to upgrade to the 2025/2026 version.
lauri_barnhart
Hello, @webtech,
Did the information provided by @Michiel.Valcke help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
