AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
plant 3D Pipe support tags
14 REPLIES 14
Message 1 of 15
william.hernandez
3844 Views, 14 Replies
We have a situation with BOM pipe support  , the issue is the that plant 3D out of the box functionality for pipe supports tags have to be unique that means if our tag is “FC23-A-1” in order to be unique we have to add extra letter or number like “FC23-A-1-(1)” , and this is not what we need , we understand that is database there is no other way to do a pipe support Tags count on the database
14 REPLIES 14
Message 2 of 15
twdtech
in reply to: william.hernandez
A support tag should be a unique number regardless of the type of support i.e. PS-1, PS-2, PS-3.....etc. Your number “FC23-A-1”, I believe, is actually a support type of which you may have multiple occurrences in a project. You could use the "ITEM CODE" property of the support to write the support type number.
Message 3 of 15
dave.wolfe
in reply to: twdtech
I suggest setting up a different property to hold the support type as twdtech says. You have to setup an annotation scheme for it similar to what this article shows.
http://www.pdoteam.com/2013/08/notes-on-supports-in-plant-3d-isometrics/
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 4 of 15
Thanks for your help I did tested and work perfect... Thanks a lot again
Message 5 of 15
Glad to help! You are welcome.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 6 of 15
BSchwartzkopf
I disagree twdtech.
A pipe support should not be a unique number every time. When using a standard shoe detail or u-bolt detail it should be the same number for multiple items. Is there another way to get this tagging fixed without setting up a comment field? Our client wants the support number in the BOM not in a comment section.
Message 7 of 15
dave.wolfe
in reply to: BSchwartzkopf
You can click the Add fields button in the iso table setup to add any property from the pipe support class to the BOM, so any field can work.
Dave Wolfe
Isaiah 57:15
EXPERT ELITE MEMBER
Plant 3D Wish list
Message 8 of 15
BSchwartzkopf
in reply to: dave.wolfe
Thanks, just getting familiar with the software.
Message 9 of 15
patpat79
Are you want to have a support out just like this?
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Message 10 of 15
EricNyh
in reply to: patpat79
I do. Smiley Happy
Message 11 of 15
BSchwartzkopf
in reply to: EricNyh
I do want that.
Message 12 of 15
patpat79
Actually to make this, i just used/created calculated properties, and changed the whole ISO config.. ^_^
Best Regards,
Pat Andres
GHD Manila
Message 13 of 15
patpat79
Though its very complicated to explain.............. ^_^, but as you see, its possible right?
Best Regards,
Pat Andres
GHD Manila
Message 14 of 15
ZZikic
Hi Dave,
We used the ITEM_CODE to accomplish this non-unique tagging of supports.  This works fine, but is there a way to suppress the "?" mark that is generated in the PCF file and BOM list for supports with no TAG value?
Thanks!
Zeke
Message 15 of 15
in reply to: ZZikic
I would love to know the answer to this question too!
”Boost
