Im having trouble with isoconfig filters/themes. I can't seem to disable model items with a status='existing' from being given a spool identifier (see spool labeled as "C" in image below).
I narrowed it down to two filters; "Components", and "NotBoltWeldFlangeGasket". (I did not create this isoconfig, and it has been severely neglected). I don't have the luxury of time to start from scratch.
If I add: AND NOT LIKE Status = 'Existing' - or a variation of that, it either overrides the other criteria, and I get instruments etc labeled as spools, or I get no spool labels at all... The syntax is a little confusing.
Any help would be much very appreciated.
Solved by jabowabo. Go to Solution.
@LiamMc-X wrote:If I add: AND NOT LIKE Status = 'Existing' - or a variation of that, it either overrides the other criteria, and I get instruments etc labeled as spools, or I get no spool labels at all...
'LIKE' and '=' shouldn't both be used here. You could try something like this:
AND NOT Status = 'Existing'
or:
AND NOT Existing = 'true'
Sweet ill give that a go thanks Jason.
I have another related issue: if I rotate my line so it runs east/west on the iso, the spool numbers disappear. Yet if I run them at 0deg, they show up :@
