Does Plant 3D have an option to use unions to connect pipe? I don't see it under joint setup; I only see couplings.
Solved by Dadspackard. Go to Solution.
Adam,
Yes they do have unions in the AMSE Pipes and fitting catalog.
You will need to add them to your spec for them to show up on the Tool Palettes.
I don't find it in edit long description items when I try to "batch assign long description styles" in Spec Editor.
