Pipe Supports not showing in BOM or labelled on ISO
Would_Ya_Just_Look_At_It
Not sure if there is a config setting here, but my pipe supports are showing and dimensioned on my ISO and set as field items but they won't show up in the BOM. Is there some special config i have to enable for this to show?
Michiel.Valcke
Do you see the pipe supports data row in the table setup of your title block settings?
If not it means you'll have to add it to the isoconfig.xml in the relevant aggregated lists under the data node, you can always copy it from an out of the box project.
if you do see it there, is your pipe support status 'existing'? it might be a part of your 'Existing Piping' theme, whose items are omitted from the BoM by default.
Also check to see to it that your 'Content Iso Symbol Definition' TYPE is equal to SUPPORT. If it is blank or something else, it might not be recognized as a support.
h_eger
@Would_Ya_Just_Look_At_It ,
for labeling on the ISO, please check whether the field assignment is set to "Tag" and not to "SUPPORTSTANDARD"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Touche!
it has been removed from the isoconfig.xml, I did what you said and used the template one and copied across and voila!  Thank you kind sir.
